fuse to run
    fuse to run
    alright i got a rockford fosgate power distribution block. my question is,
    what fuse amp rating do i run on the distribution block? i have a 1000 wat amp and a 600 watt amp.
    any help would be appreciated!
    I was running a JL 500/1 and a Kicker SX650.4. Under the hood for the inline fuse by the battery I used a 150amp and then on the distribution block I had two 60amp fuses. I never had any problems with it as far as blowing fuses or anything. Hopefully this helps.
      thanks man. im gonna buy some at best buy today.
        What size wire are you running?
        YouTube Clicky!!
          8awg from amps to distribution block.
          4awg from distribution block to battery.
            mine is zero gauge to distribution block and 2 gauge to amps.
            my new turbo build
