speakers specs
    speakers specs
    1990 HONDA ACCORD 2DR COUPE
    Speaker Specifications
    Location Size Depth
    Front Speaker 6.5 1.75
    Rear Speaker 6X9 4
    www.pioneerelectronics.com
    is this true?
    http://www.cb7tuner.com/vbb/showthread.php?t=186
    Q- what size are the front speakers?
    A- DX/LX= 6.5" EX/SE= 5"
    Q- What's the maximum depth my fornt speakers can be?
    A- 2-1/8"
    Q- What size are the rear speakers?
    A- DX/LX= 6.5" EX/SE= 6x9"
    Q- what's the maximum depth my rear speakers can be?
    A- DX/LX= 2-3/4" EX/SE= 3-3/4"
      Be careful with online info, Crutchfield was wrong about my 93. The best way to see what you have is, well, pop your door panel and look in the trunk. I can say from experience that the front doors won't fit some 6.5"s and the mounts are VERY shallow. Pioneer and Cadence have some with <2" depth and you MAY have to go with 5.25". On the back deck, just party on with whatever fits. Just bend over backwards to see what size you have back there. Good luck!
        i got some infinity 6.5's for my front doors and they only fit cuz the came with an adapter the moved them out just far enough to miss my window when it was down.
        The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
          thank you friend!
            Usually the rear deck speakers don't fit because the trunk lift bars end up getting in the way. You can cut the ends of them off to get a bit more space (an extra .5"-1") if the magnet is too large but the basket isn't.
            Also if you have the 5" molded ported assemblies up front (only if you have an EX/SE), you can swap the entire housing out for the housing on a DX/LX to fit a 6.5" speaker. Some people think that the 5" molded housing sounds better with an aftermarket speaker than a 6.5" will, but I disagree and went with the 6.5's in mine and am much happier with the sound. I'm not certain that they are all the same, but the housing from a '96 fit in mine (93) so anything '90-'97 would likely be just fine for you.
            Usually you can get a louder 6.5" driver than a 5" driver to help with the fade of music. I found with aftermarket 5" (head unit only, no amp) the rear 6x9s drowned out the fronts unless I did a 70%+ fade to the rear. With the 6.5's its more like 60% faded to the rear to seem matched.
            Shankenstein is right on with mounting depths up front. Very shallow so purchase accordingly.
            Last edited by TheFirstNutZo; 10-19-2009, 04:36 PM. Reason: spelling issue, add'l info on housings
