Intermittently working speaker
    So for the last few years, my (OEM) right front speaker hasn't been working. But I recently found that pushing in on my (OEM again) head unit gets the speaker to work as long as I keep constant pressure against the head unit. Would removing the radio and checking the cables in the back possibly bring my speaker to work consistently? or could there be some other problem? I've seen a few other CB7's with the same intermittent-speaker problem.
    Original-Owner 1991 Honda Accord
    2005 Acura TSX 6MT
    2010 Mazda Miata Grand Touring
    Sounds like a loose connection behind the headunit.
    Pull the head unit out, and disconnect the plug then reconnect it and see if that helps.
    My 5.7 LS1 Holden Ute
      Heres how to take out the stock Stereo http://www.cb7tuner.com/vbb/showthread.php?t=68700
        if its all oem and its not getting a proper connection then the problem will probably be in the plug unless all the wires were cut once for some reason. might have to switch to an aftermarket HU and cut the wires to get it fixed.
          Just try to find a new OEM harness or aftermarket HU. Chances are the wire is loose in the harness and that's not easy to fix.
            Thanks for the replies, guys. I'll remove the radio tomorrow and try reconnecting everything.
            2005 Acura TSX 6MT
              i got the same same problem but with an aftermarket radio and ever time i take it out and check the cables i see nothing wrong wit the connectios or the cables
              CALI LIFE STYLE
              http://www.cb7tuner.com/vbb/showthread.php?t=145883
                take the connector behinf the radio and tug on each of the wires and see if they are loose, that might be causing the problem
                Originally posted by Quashish
                Holy crap thats a clean F series. jellish mang.
                Quashish dictionary
                Jellish: (adjective) Jel-%i'sh+#
                To envy something to point of almost blowing a load involuntarily.
