How to take out the front Speakers on a 91 accord sedan ex?...
    How to take out the front Speakers on a 91 accord sedan ex?...I tried search on the search tap and google and other forums can't find an instruction got my 6'9 done now the fronts...
    Take the door panel off, and remove the screws holding it in.
    For all your Powder Coating Needs and More!
    www.getcolorcoated.com
      You serious the whole door panel has in gut it all up i cant just take off the lid on the speaker panel?
        really not hard to take off a door panel. couple screws and a couple pop clips and it slides right off.
          No. Taking off the lid for the speaker panel dont give you acess to the screws that hold the speaker.
            I dont think there is anything that CANNOT be removed from the car. Just look at it closely. I have a 92 LX and it doesnt get any easier
              I just took a short phillips head and did it with the door panel still on for the most part. I held the bottom of the door panel out with one hand and unscrewed the speaker with the other. This is the lazy way lol. It'd be easier to just take the whole thing off.
                Just remember to unplug your wires! Don't rip them off lol
                For the door handle, pull it all the way open, rotate the plastic clip attached to the wire with a flathead screwdriver, then pop it off with your fingers (Don't drop it in the door lol)
                After all the screws are off it slides upwards, cake!
                Built & Boosted.
                  any pictures on how to take it out?..
                    here you go man.
                    http://www.cb7tuner.com/vbb/showthre...+panel+removal
                    this will help a lot.
                    Originally posted by visualpoet
                    some owners think it's the best thing since titties
                      Screws are located, in the door handle...
                      pop off the little stub in the center grab bar...then move to right above the light on the door...there is one screw there. You should have a total of 4 screws
                      gently pry off the panel...disconnect the power windows, locks, and the little cord to the light on the door..remove panel.
                      Then you should be able to see the speaker...4 screws come off..and then the speaker should come off...pull off the two wires, and speak is off.
                      Mission Accomplished.
                        dont forget the door handle has to slide toward the front of the car or youll break the tabs on the back by The NooB Yank It Off move. OP youll do fine bro just dont be to lazy and take your time.
                        clicky the siggy!!!
                        ARCADIA GREEN MEMBER #20
                        AIM=SleepygreenCB7
                        Yahoo=annamaineeak@yahoo.com
                          remove all the screws on the door panel along with the stubs and that shoulb be it
                          CALI LIFE STYLE
                          http://www.cb7tuner.com/vbb/showthread.php?t=145883
                            also dnt forget the piece of metal attatched to the handle that opens the door
                            ♦░I'm so JDM I sleep on the right side of the bed░♦
