high pitch whine out of my speakers
    I just installed a new system in my 1990 coupe and I'm getting a high pitch whine out of my speakers. What can I do to make it stop? Thanks
    What all did you put in it? Have you double checked your grounds?
      what kind of "system" did you put in?
      I ♥/Miss My Coupe
        I put in a new deck, alpine type s componants in front and type s 6x9s in the back, a 4 ch amp for the speakers, a sub and a 2 ch amp briged. I have the power wire running down the right side and the rca and speaker wire on the left. I drilled and taped a hole under the rear seat for the ground wires.
          make sure your big ground and wire going to the amp do not criss-cross, that will give you a high pitch wine through the speakers
            The power wire or the speaker wire and rca?
              its most likely your ground wires for the amp make sure they are connected to bare metal, when there not that can make that high pitch noise, try hooking the grounds to another spot that should do the trick
              lovin every minute of it
                Thanks for the help! The whine is gone.
                  You should also add a really good ground to the head unit. It will prevent problems in the future and can also protect the deck from dying.
                    I have had multiple problems out of pioneer head units causing feedback (whine). if you have a ghost whine that you can not get to go away and are using pioneer head units... throw em out.... or you could pay to have it shipped off and fixed if you like it that much.
                      Or do what everyone else with a pioneer does. The problem is a ground fuse blows and can't easily be replaced in the unit. So run a ground wire around the RCA outputs and that fixes it.
                        or you can just replace the pico fuse yourself if you'd like
                        Purchased from: 90-JDMCB7, cb95spd, 92_dr_p, ukaccord92, slammed4thgen, 93a-lude, h22anow, cb7addicted, H22WAGON93, tonymontana1204, agol, Joshy
                        Sold to: di2accord
