radio shuts off
    radio shuts off
    when i turm my headlights on the radio shuts down.
    run your car not your mouth.
    Does it do it when you turn anything else on?
      What radio? OEM or aftermarket? Did you just install it? Has it been working fine and just started doing this? Need a few details.
        Need more details here.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          bad ground, run ten gauge
            This question is difficult to answer since you didn't state whether it is oem or aftermarket.
            Bisimoto Engineering
            1) Call 1-888-9BC-MOTO(888-922-6686 ext. 1) Mon-Fri 9am-6pm PST
            2) Email me, robert@bisimoto.com
            3) Contact me on AIM, robert@bisimoto.com
              more info buddy
                Use a multimeter and test the harness. Like someone else mention, there is a high possibility about the ground.
                Right Rear Spkr (+) Red w/ Yellow Stripe
                Left Rear Spkr (+) Blue w/ Yellow Stripe
                Power Antenna Trigger Brown w/ White Stripe
                +12 Volt Ignition Wire Yellow w/ Red Stripe
                Right Rear Spkr (-) Brown w/ White Stripe
                Left Rear Spkr (-) Gray w/ White Stripe
                Ground Wire Black
                +12 Volt Battery Wire White w/ Yellow or Blu Stripe
                Dash Light Dimmer Wire
                Left Front Spkr (+) Blue w/ Green Stripe
                Right Front Spkr (+) Red w/ Green Stripe
                Left Front Spkr (-) Gray w/ Black Stripe
                Right Front Spkr (-) Brown w/ Black Stripe
