ok. i did a drivers side wire tuck a week ago and now when i turn my radio on it dims everything when bass hits. i suspected a weak battery and in line to get an optima yellow top, in the mean time could it be anything else? cuz i used my lil bros car to jump mine and it still does the same... I need help if its the tuck then im seriously gonna hate it i love how it looks tuckd.
after wire tuck problems
Originally posted by sleepygreen View Postok. i did a drivers side wire tuck a week ago and now when i turn my radio on it dims everything when bass hits. i suspected a weak battery and in line to get an optima yellow top, in the mean time could it be anything else? cuz i used my lil bros car to jump mine and it still does the same... I need help if its the tuck then im seriously gonna hate it i love how it looks tuckd.
My 5.7 LS1 Holden Ute
You probabally need to ground your engine/battery better. do you have a system in it?
Also take off all your grounds and clean the paint off of the body where they touch, wire brush the terminals that bolt to the body, and clean your battery posts and battery terminals.-Big3racing.net-
My Build Thread. Many pics.
You mean the radio dims, or the headlights? Check all your grounds as above.
Other than that nothing should really have effected the stereo.
nope havent fixed the problem, lol its 3 in the morning here... but describing whats happening... i already know my batt. is weak. so i use my lil bros car to jump to get it started so i can use alt. power. everything dims my inst. lights headlights, also the temp gauge goes way up then down, and the rpm of the motor is idle while the rpm gauge it self looks like its possessed but only when i turn the radio up... i even used my lil bros batt. in jump mode to rule out the weak batt. and it does it but not as bad...
how many volts your at, its something you did, take things apart and check.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View Posthow many volts your at, its something you did, take things apart and check.
Check the volts at the battery, While the car is off and when it is running.
Remember a chain is only as strong as its weakest link - If the battery is bad, replace it before trying to diagnose other problems.
Originally posted by evil_demon_01 View PostCheck the volts at the battery, While the car is off and when it is running.
I would defo say the battery. My buddys car used to do that. Then get got a new battery and a cap. and it fixed the problem.
Of course he had a massive system (3000w) at the time and the little puny battery couldnt take the power demands.PSN
Vash744
MRT 1992 EX Coupe "The Jerk"
2009 Subaru Impreza 2.5i Premium Hatchback
2008 Honda Fit Sport (Totaled out - Death by fallen tree)
1993 CB7 Sedan LX (Totaled out)
1991 CB7 Sedan EX (Dead and Junked)
