after wire tuck problems
    ok. i did a drivers side wire tuck a week ago and now when i turn my radio on it dims everything when bass hits. i suspected a weak battery and in line to get an optima yellow top, in the mean time could it be anything else? cuz i used my lil bros car to jump mine and it still does the same... I need help if its the tuck then im seriously gonna hate it i love how it looks tuckd.
    clicky the siggy!!!
    ARCADIA GREEN MEMBER #20
    AIM=SleepygreenCB7
    Yahoo=annamaineeak@yahoo.com
    Did you just do a tuck, or did you relocate the battery at the same time?
    My 5.7 LS1 Holden Ute
      You probabally need to ground your engine/battery better. do you have a system in it?
      Also take off all your grounds and clean the paint off of the body where they touch, wire brush the terminals that bolt to the body, and clean your battery posts and battery terminals.
      -Big3racing.net-
      My Build Thread. Many pics.
        just a tuck...
        clicky the siggy!!!
        AIM=SleepygreenCB7
          Ground. That's all it is
          NEW CB
          old Darkcloud : 1990 Accord EX MRT
          new
          DARKCLOUD : 90 ACCORD EX MRT
            found the issue yet?
            ____
              You mean the radio dims, or the headlights? Check all your grounds as above.
              Other than that nothing should really have effected the stereo.
                nope havent fixed the problem, lol its 3 in the morning here... but describing whats happening... i already know my batt. is weak. so i use my lil bros car to jump to get it started so i can use alt. power. everything dims my inst. lights headlights, also the temp gauge goes way up then down, and the rpm of the motor is idle while the rpm gauge it self looks like its possessed but only when i turn the radio up... i even used my lil bros batt. in jump mode to rule out the weak batt. and it does it but not as bad...
                clicky the siggy!!!
                AIM=SleepygreenCB7
                  how many volts your at, its something you did, take things apart and check.
                  Retro!
                  Hater
                    where do i check my volts? ill take a look tommorrow... i couldnt have done anything wrong... i just simply moved the wires, extended each wire ( one by one) and put everything back together... rite? or is there a missing element?
                    clicky the siggy!!!
                    AIM=SleepygreenCB7
                      Check the volts at the battery, While the car is off and when it is running.
                      Remember a chain is only as strong as its weakest link - If the battery is bad, replace it before trying to diagnose other problems.
                        ok kool. i just want to rule out other suspects... it bugs the crap out of me...
                        clicky the siggy!!!
                        AIM=SleepygreenCB7
                          sounds like a ground problem to me....
                          1990 Accord LX Sedan~Sold
                          1993 Accord EX Sedan~Sold
                          1995 Suzuki GSX-R 750~Totaled
                            ground to me.
                              I would defo say the battery. My buddys car used to do that. Then get got a new battery and a cap. and it fixed the problem.
                              Of course he had a massive system (3000w) at the time and the little puny battery couldnt take the power demands.
                              PSN
                              Vash744
                              MRT 1992 EX Coupe "The Jerk"
                              2009 Subaru Impreza 2.5i Premium Hatchback
                              2008 Honda Fit Sport (Totaled out - Death by fallen tree)
                              1993 CB7 Sedan LX (Totaled out)
                              1991 CB7 Sedan EX (Dead and Junked)
