I have my amps mounted on the rear seat, I am running 16 gauge wire from my 4way amp directly to the rear speakers (short run), then I ran 16 gauge to behind my deck (long run), and then connected it to the to stock front speaker wire via the harness adapter (short run). As far as my front speakers are concerned the amp might as well be behind my deck. (Alpine 40w RMS x 4)
The higher the gauge wire (22awg), the more resistance there is, and less distance you can run it while maintaining power levels compared to using a lower gauge wire (16awg)for the same run. The amount of loss also goes up with the more power you run, that loss is then turned into heat.
