which amp to use?
    which amp to use?
    im planning my speaker setup in my wagon. these are the speakers im planning on using :
    2 Alpine Type-S SPS-609 6x9's in the rear
    System Components: 2 speakers
    Speaker Type: Coaxial - 3-way - passive
    Speaker Diameter: 6" x 9"
    Nominal (RMS) Output Power: 85 Watt
    Max (RMS) Output Power: 260 Watt
    Response Bandwidth: 65 - 23000 Hz
    Input Impedance: 3.6 Ohm
    Sensitivity: 90 dB
    Connectivity Technology : Wired
    Additional Features : Angled tweeter
    2 Alpine Type-S SPS-400 4" coaxial speaker in headliner
    Speaker Type: Coaxial - 2-way - Passive
    Speaker Diameter: 4"
    Nominal (RMS) Output Power: 45 Watt
    Max (RMS) Output Power: 140 Watt
    Response Bandwidth: 80 - 22000 Hz
    Sensitivity: 87 dB
    Connectivity Technology: Wired
    Alpine Type-X SPX-17REF Components in the front
    Speaker Type: Component - 2-way - Passive
    Nominal (RMS) Output Power: 75 Watt
    Max (RMS) Output Powe:r 225 Watt
    Response Bandwidth: 35 - 40000 Hz
    Sensitivity: 89.5 dB
    i want to wire these up to a four channel amp. i know i have to use bass blockers for the 4" speakers in the back and the 6x9's.
    what do you guys think of these speakers and what kind of amp should i b looking at (amount of watts??) ?
    alone in this game . ::My Ride My Way::
    Might as well get an alpine amp too.
    PDX 4.100 just to have matching products.
    Don't buy a bass blocker. Use the built in xover on the amp.
    YouTube Clicky!!
      thnx man. uve been helpin me out alot.
      anyone have any experience with these speakers ?? how do they sound on a 4channel amp?
        I've dealt with alot of stereo stuff including Alpine head units but never with their speakers. From my experiences so far they should be good. I used to have a Kicker 650.4 on two component sets and it was great. I would say something around 5-600 watts. You shouldn't have to turn up the gain too much and it won't be working too hard to put out the power needed.
          well..you might wanna check out the Alpine MRP-550 which is 100Wx4 RMS wise..800W amp..im pretty sure they should pick up the Type S speakers..i have type R's and im using a 600 Watt amp and i think they need a little bit more..thats why im recomending the 800Watt one..but they still sound nice!..but it's up to you and your budget!..=]
            Are you sure I don't need a crossover for the rear? In the rear I'm going to have 4 speakers (2 4" coaxial and 2 6x9's) and the components in the front so there wouldn't be enuff channels on the amp to hook them up.
              what kind of deck do you have? It may have a built in hpf. (high pass filter)
              YouTube Clicky!!
                i dun have a deck yet. still have the oem radio. in ma old thread (cb9 audio help) u sed i need a bass blocker for the rear since im going to use my 8" jl audio sub.
                  i always reccomend elementaldesigns.com i use their subs and they are excellent i plan on getting one of their amps all the reviews are 5/5 check them out!
                  One mans turd is anothers golden nugget
                    I forgot you had an oem deck. Well think of the xover on your amp as an electronic bass blocker. A good amp will have a separate one for the fronts and rears. What you can do is hook your components up to the front speaker outputs and set the xover to about 60hz. Then wire the 4" and 6x9s in parallel to each channel of the amp and set the rear xover to about 80hz and have your sub play from 80hz down.
                    YouTube Clicky!!
                      why would u hook components up to deck power and then little 4'' speakers to the amp?
                      the little 4 inch speakers should be on the deck power and crossover. then the 4 main speakers on the amp. The components want power and not deck power.
                      and get a new deck. you wont have to deal with the things to make the oem deck work with your amp. you will also love the sound quality the new deck puts out.
                      Retro!
                      Hater
                        im not hooking up any speakers to the deck. the components wil be connected to the amp and so will my 6x9's and 4" coaxials. what im trying to figure out is how to connect the 6x9's and 4" speakers to the two channels on the amp.
                        and yea i am planning on getting a better deck. nothing to expensive though.
                          a deck with front/rear/sub output works great.
                          honestly i think it would be hard to seperate the gains between a little 4'' speaker and the 6x9 with the front components. hooking them up in paralell to the amp will only yeild no way to adjust the gains. you can probably say that the 4'' will top out before the front and the rears.
                          If you are going to go with it, id hook the back up together, then the front off its own channel. that way you have the ability to distinguish front and rear fade. but you still are going to push those 4'' speakers.
                          if anything, get a little amp to run the 4'', and then the alpine to run the 4 speakers inside, that way you can set the crossovers correctly and seperated without worrying. possibly with a external crossover, not really needed but can be used.
                          Retro!
                          Hater
                            how would i go about doing it this way? im a complete noob to all audio so evry little detail would be appreciated. thnx
                              Hi,
                              Why shouldn't we use bass blockers? What if I have type S Alpine SP600C components without an amp, could I use bass blockers? I was told that the cross over built in the speakers are not great.
                              Thanks.
