i have a 91 accord and i want to put 2 12in subs in the trunk. which way should i face them facing the front or the back?
How to run amp wires in your CB7
Originally posted by biggs honda 50 View Posti have a 91 accord and i want to put 2 12in subs in the trunk. which way should i face them facing the front or the back?
face them towards the cabin.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
Originally posted by visualpoet View PostHow can your amp be too powerful to connect it there at the fuse box? The wire is lugged and bolted down to the positive cable coming from the battery. Power wise there is not a noticeable difference bwtween where I'm connected and the battery; maybe .001 volt. Your 1200 watt Sony will be just fine lugged there.
-mak
Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
Traded With: cb95spd, chessboxer, sohc em
[ Completed | Pending ]
Originally posted by mak View PostActually, the stock wire coming from the battery to the fusebox is only 8 AWG, and the pictures posted appear to have 4 AWG tapped into the fusebox.. if that's the case, and if the amp(s) connected to that 4 AWG wire require a wire larger than 8 AWG, you'd need to at least upgrade the battery to fusebox wire to 4 AWG, or tap it directly to the battery.
-mak
Originally posted by visualpoet View PostLast edited by Juan4DCB7; 08-02-2009, 09:21 PM.
Originally posted by visualpoetsome owners think it's the best thing since titties
Originally posted by Juan4DCB7 View PostThis might be stupid, but is there any problem having the power wire go straight from the battery to the amp which is about 600w? and if you can take a picture of the inside of the fuse box, because i am not really sure what you did there, I would appreciate it. thanks.
Originally posted by visualpoet View PostNz problem with running straight to the battery. I don't need to take a pic, if you pop the cover on yours, the hot wire is bolted own to the fuse block right there where the amp wire goes (you'll see it, it's a philips head machine screw). I just unbolted it, slipped the lug on my amp wire in and bolted it back down.
Originally posted by Sarthos View PostI managed to run two runs of 0 gauge and a run of 4 gauge wire from the engine bay to the trunk, along with 6 RCA wires and 12 gauge wire to all my speakers. If anyone needs to run a lot of wire like that I can explain it.
The 6 RCAs are because I have amps for front speakers, rear speakers, and subs, so all my stereo's RCA outputs are being used. The 4 gauge is what I first ran to my 4 channel amp, but the 2 runs of 0 gauge are because I have 2 batteries in my trunk so one of them is going to the alternator and the other to the engine block. And once I get home I might take some pictures and show how its done.
