help with my amplifier.
    hello everyone.
    just got a new pair of alpine tipe E 10" and custom box.
    i trying to see what amp. would be good for them. what caind do you recomend?
    thanks
    Alpine SWE-1043E
    Peak Power: 500W
    RMS Power: 150 W
    Frequency Response: 30Hz - 1kHz
    Sensitivity: 88.4dB/W (1m)
    Installation Diameter: 235mm
    Depth: 139mm
    well, you'll want something around 300 rms at 2ohms, im at work so cant look, but alpine would probably have something around there. soundstream too, both for a very decent price.
      gwt sumthing that 'll blow them 10's
      Summer 11' Big plans (Bodywork/paint/rims etc..) in Progress STAY TUNED
      CLICK THE PIC
        Originally posted by paflores9 View Post
        hello everyone.
        thanks
        Alpine SWE-1043E
        Peak Power: 500W
        RMS Power: 150 W
        Depth: 139mm
        I have a Hifonics amp and I love it. this one has 600 watts.
        http://cgi.ebay.com/HIFONICS-BXi608-...3A1|240%3A1318
          They are rated at 500w a piece so I would say go with something around 600 or so. Clarion used to make some decnt amps that were easy on the wallet and were class d amps. The last one I saw was like 400w and it was only around 200.00. It really depends on your spending limit. If it were mine I would say go and get the JL 500/1 and you wouldn't have any worries. I had that amp and ran 15's, 12's, and everything else off of it and never had a single problem. Too bad it got stolen.
            You're looking at the peak rating. Never go by peak power to determine what amp to get. I suggest a nice 400w rms amp.
            YouTube Clicky!!
              get a real amp, check out some of the smaller JL mono amps, or even Boston Acoustics. I just sold my JL 500/1 for $200. Good deals are out there, just gotta look. Craigslist almost always has good amps for sale, that's where I sold mine.
                new amp
                so i got a new amp for the type E and it works realy good, but i have a little problem it continues blowing the fuse.
                what can i do?
                thanks
                this is the amp Kenwood KAC-7201
                800 Watts max power
                150 Watts x 2 max (4 ohms) RMS
                460 Watts x 1 (4 ohms) RMS
                Frequency response 5Hz to 50kHz
                Built in variable low pass filter (50 - 200Hz)
                Built in variable high pass filter (50 - 200Hz)
                Bridgeable
                Speaker level input
                Gold plated input & output terminals
                Integral cooling fan
                Complete with full fitting and operating guide
                  Can you describe what it does before the fuse blows?
                  YouTube Clicky!!
                    so i turn on the radio on and if i used on the volume before or at 20 it works just great but if go over 20 it blew.
                      how are your gains set? and what kind of head unit do you have?
                      YouTube Clicky!!
                        haha are u Bridging the amp??? lol makin it mono where its only meant to run 4ohms and ur running 2????
                        Members Ride sold...
                        I'm back...... with a coupe. oh boy here we go.
                          the deck is a sony explod, i used this amp in another accord with no problems, i double checked all the wires and non of them is touching anything else, i dont know if putting a bigger fuse out of the battery would help, i am using a 30 fuse out of the battery, do you think i need a bigger one?
                            Are you talking about the fuses in the amp, or the fuse in-line with the power wire. loud92 made a good point about the bridge. How are your subs wired?
                            YouTube Clicky!!
                              Its the fuse in-line with the power wire.
                              but i think or i hope i fixed alredy. lol
                              i put a bigger fuse a #40 and its working god so far.
                              so i will let you now.
                              thanks for all the help.
