i hooked up a system hear a whinning noise while driving gets louder when going faster can someone help its annoying:angry
whinning noise through speakers
X2 check the grounds. Poor grounds often cause alternator whine.
The ground should be on clean steel (paint sanded off) and on a suitable part of the body. Then paint over the ground once it has been connected to prevent rust
My 5.7 LS1 Holden Ute
make sure the RCA's are ran on the oppisite side of the power cable for the amp, and if the above suggestion for the ground cable is fine, check your amp itself, then the stereo itself. I mean replace them with something else. I don't have many posts, but I am 30, and a reputed bass head. All of these suggestions are problems I have had.F22a1, T3/T4 turbo, Greddy Type RS BOV on left-over AEM CAI piping, Turbo XS manual boost controller, PHAT intercooler, Crzy tuning, Walbro fuel pump, AEM FPR/fuel rail/pulleys/cam gear, Gude cam and throttle body, MSD ignition/cap/coil, NGK wires and Iridium plugs, Fidanza flywheel, ACT clutch, Nuespeed short shifter
9 lbs on stock internals (for 10 min)
16.2 1/4 mile with basics
??.? 1/4 mile with turbo
139 hp with all bolt-ons
??? hp with turbo
STAY TUNED
Originally posted by carbonaccord69 View Postmake sure the RCA's are ran on the oppisite side of the power cable for the amp, and if the above suggestion for the ground cable is fine, check your amp itself, then the stereo itself. I mean replace them with something else. I don't have many posts, but I am 30, and a reputed bass head. All of these suggestions are problems I have had.
Try connecting a "Ground loop isolator" ..Works great and super easy to install. you can get one at radio shack or audio store.
their like 5-10 bucks.
all you have to do is connect the rca's into the isolator right before the amp.
You can also get this kind of interference when you run your main power wire to your amp from the battery on the same side as the RCA cables as stated by the quote. I myself had an issue with my fuses popping on my amp, I re-routed the cables and sanded and re-grounded the wires, and problem solved.
Good luck
