Originally posted by demortey@mac.co
View Post
Best location to hide amp
well, usually your sub and box weighs enough, although it all depends on the box and sub.
for example i got 2 12s in a vented enclosure, weighs a ton! two people are needed just to lift it, barely fit in the trunk and i had to remove the trunk liner of the wheel wells just to get that extra hald inch on each side so the box could fit between the wheel wells. i wouldnt of had a trunk at all if i hadnt done this.
so all that to say that mine do not move what so ever.
before those i had one 12 in a ported enclosure and it was pretty heavy also, it never moved much.
i have had mine on the back seat. i have also put it down by the spare tire. its a lil harder to put it in the donut area butit never over heats. just make sure no to crush it.
Red Wagon DD - 1993 EX
http://www.cb7tuner.com/vbb/showthread.php?t=172734
Gray Wagon Project - 1992 LX
http://www.cb7tuner.com/vbb/showthread.php?t=166337
Originally posted by visualpoet View PostI'm not a fan of mounting under the seats. There's too much chance of a backseat passenger kicking it and breaking connections or worse. Mine hides behind the back seat.
Something about the angle I took this at makes it look more off-center than it really is. It sits on 1" copper legs to allow the stinger crossflow fan on the left side to blow air under it.
That fan is sweet , where do I get oneWE MISS YOU JO(9-04-2008)
