I just got a Kenwood KVT-717. can someone tell me how to bypass the parking brake bypass
Kenwood KVT-717DVD
taking the parking brake wire and t tap or connect it to the ground. if that doesnt work use a toggle switch and keep it grounded.Members Ride sold...
I'm back...... with a coupe. oh boy here we go.
can someone tell me what this wires are for on the receiver unit blue, blue/white, and pink/black http://akamaipix.crutchfield.com/Man.../113717DVD.PDF on page 96
the blue white wire is the amp turn on wire, it will turn on and off your amp when you turn the radio on and off, and the pink/black wire is only used for kenwood amps, that will let you control the amp from the radio but you will also need a data cable to be able to use it, so if u dont have any newer kenwood amp dont worry about that wire.
Originally posted by ProJect View Postthe blue white wire is the amp turn on wire, it will turn on and off your amp when you turn the radio on and off, and the pink/black wire is only used for kenwood amps, that will let you control the amp from the radio but you will also need a data cable to be able to use it, so if u dont have any newer kenwood amp dont worry about that wire.
-mak
Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
Traded With: cb95spd, chessboxer, sohc em
[ Completed | Pending ]
