Kenwood KVT-717DVD
    Kenwood KVT-717DVD
    I just got a Kenwood KVT-717. can someone tell me how to bypass the parking brake bypass
    taking the parking brake wire and t tap or connect it to the ground. if that doesnt work use a toggle switch and keep it grounded.
    Members Ride sold...
      do you guy know if the brain box has an Acc wire or is it just power and ground
        can someone tell me what this wires are for on the receiver unit blue, blue/white, and pink/black http://akamaipix.crutchfield.com/Man.../113717DVD.PDF on page 96
          the blue white wire is the amp turn on wire, it will turn on and off your amp when you turn the radio on and off, and the pink/black wire is only used for kenwood amps, that will let you control the amp from the radio but you will also need a data cable to be able to use it, so if u dont have any newer kenwood amp dont worry about that wire.
            ..and solid blue should be your 'Power Antenna' wire, which will make your power antenna (if you have one) go up and down when you turn the radio (am/fm) on or off.
            -mak
            Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
            Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
            Traded With: cb95spd, chessboxer, sohc em
            [ Completed | Pending ]
              -mak
                what about the blue wire. and do you know if the receiver unit has a remote turn on that goes connected behind the stereo or is it just the power and ground. thanks for ur help
                  ok coo thanks guys
