Ohms
    Ohms
    What's better 2ohms or 4ohms?
    Thinking about get 2 Type-R 12's or 1 15 Type-R what wud be better for my CB!!!
    2 ohms
    Originally posted by d112crzy
    I quit jobs as much as I swap engines.
      only depends on what amp you have some Amps put out max rms power at 4ohm and some at 2ohm just depends on what amp u have, doesnt mean a 2ohm or 4ohm sub is better then the other
      F/S:Pioneer Premier Deh-880prs w/ ipod adapter $220
        The ohm rating is just for people that want different things, As mentioned it has to do with the amp. Get the sub that will match up best to your amp.
        A dual 2 ohm sub can either be wired to one single 4 ohm or a single 1ohm. A 4 ohm sub can be wired to a single 8 or a single 2.
          jus like everyone is saying depends on wat you got to use...but the lower you go the harder it slams...so 2 12" at two ohms w/ the right amp will slam hard...
            Not entirely true.
            Amplifiers are, for the most part, more efficient at higher ohm loads(4 ohms, 8 ohms, etc) and will produce less heat at higher ohm loads.
            Generally, you can find a nice 2 channel amp that will do, for example
            200W RMS x2 @ 4 ohms
            400W RMS x2 @ 2 ohms
            800W RMS x1 @ 4 ohms bridged
            In this case, if you had 2 - 4 ohm DVC (dual voice coil) subs, you could either wire them at 400W RMS x2 @ 2 ohms (1 sub wired to each channel) or wire them at 800W RMS x1 @ 4 ohms bridged (both subs 'bridging' the two channels). The later scenario, 800W RMS x1 @ 4 ohms, will produce the same amount of power as 400W RMS 2x @ 2 ohms, and the subs will still wire to the amp properly, but there will be less strain on the amp because of the higher ohm index.
            ________________________________
            To the OP: What amp are you going to use to power the sub(s), and how many subs are you planning to buy?
            -mak
            Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
            Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
            Traded With: cb95spd, chessboxer, sohc em
            [ Completed | Pending ]
              2 12's have more surface area than 1 15, but if you are going to port them I would go with the 15 unless you dont mind not having a trunk.
              YouTube Clicky!!
