alot of guys say do this and do that...i want to know the CORRECT way of installing an amp
correct way to install amp?
how to
make sure you have a good ground(black) i used one of the nuts on the rear shock mount at the top and it was the best place for my 4dr and run the power(red) to the the amp then once you have all the wires in the right spot hook up the power(red) to the batterie positive side withthe blue wire to the radio remote wire and the low jacks and bass away :tu
Originally posted by 93f22sleepermake sure you have a good ground(black) i used one of the nuts on the rear shock mount at the top and it was the best place for my 4dr and run the power(red) to the the amp then once you have all the wires in the right spot hook up the power(red) to the batterie positive side withthe blue wire to the radio remote wire and the low jacks and bass away :tu
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
It's pretty much upgrading the stock main electrical wiring to a larger guage.
http://www.the12volt.com/installbay/...TID~73496~PN~1
