piggy back amp
    piggy back amp
    hey. Ive noticed on some bigger amps that there is a couple rca's that are labeled pass thru. does this meen that I can use these outs for the next amp? is this signal boosted, or low watt like from hu?
    also, can I take a second amp, and hook it up so that the speaker outs on the first amp becomes a set of high levels for the second amp? what do you think will happen? I only have one cheap amp(rampage lol) to experiment with. any body done this? would it change ohms? increase watss? or would I be visited by that acrid smell of a burning circiut board
    you'll love my nuts!
    The RCA outputs will just go to the next amp's RCA inputs. Nothing special there, no significant change.
    And most of the high-level inputs state a maximum input power, usually within the range of a HUs power, but they'd be overpowered by an external amp's output. And the high-level inputs just use a simple circuit to bring the signal back down to the level of the RCA (low-level) inputs.
    Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
