6.5 inch Front Door Speakers, MAXX size
    Dont use mdf unless you make it waterproof
      Does it fall apart or something when it gets wet
      My 1991 Accord DX
        i dont know either.
        Originally posted by toycar
        Braking the bank, maybe. Feeling like a boss, likely.
          No but it will get moldy and make you sick
            Originally posted by CB7_AUST
            I havent go time to make an MDF one.... so i was just thinking of placing a couple of washers under the screws to push the speaker out a bit..this would work too right? OR do i need to create a tight seal around the actual speaker
            If the speaker isn't sealed to the door nice and tight, you'll lose a lot of midbass response.
            I have Polk SR6500 components mounted directly to the metal door pane and they clear the window just fine.. there's even a small gap behind the magnet when the window is down. My SR6500's are 2-9/16" mounting depth.
            I used to have Polk DB6501's that were, I believe, 2 5/16" mounting depth, those fit fine as well and are a common mounting depth amongst component speakers.
            When MDF gets wet, it swells up and the wood becomes, more often than not, useless. If the water damage is sever (more than a couple of tbs I'd say) the wood will swell up to a point where you won't be able to sand the damage away.
            For custom door rings/spacers, I'd recommend birch ply. I've used birch ply on custom installs for years and it's very rugged wood, especially compared to MDF and HDF.
            -mak
            Bought From: MadSpleen85, jimy, CB7_ACCORD (kouzie), Chrisfrom1986
            Sold To: vinbon63, chessboxer, darkfusion42, LowNknoxville, bowzil, 1993hAccord, mcdizzle, 93accordfreak, lilb_1979, rocketman_471, Bad_dude
            Traded With: cb95spd, chessboxer, sohc em
            [ Completed | Pending ]
              Thanks for the info so where can i get birch ply?
              Does Home Depot have it?
              My 1991 Accord DX
                Yes.
                Home Depot, Menards, etc - they should all stock Birch Ply.
                The Menards here sells Birch Ply by the 1/4, 1/2 and full sheet as well. For two (2) door rings you'll only need 1/4 sheet of 1/2" to 3/4". I'd go with 1/2" since it's all you should need for most components/speakers, and you can double it up if need be since 1/4 sheet of Birch Ply is 4' x 2'.
                -mak
                  Alright thanks for the help.
                  My 1991 Accord DX
                    Anytime
                      also MDF if u paint it works fine. i would recommend the truckbed coat from a parts store.
                      i favor MDF because i have tons of scrap for random uses. lol but ur deepest u can go is endless.... i used 3/4 brackets/rings for my speakers everything clears the panel fine .... just another choice!
                      Members Ride sold...
                      I'm back...... with a coupe. oh boy here we go.
