Windows Trim???
    Windows Trim???
    ok my accord has some problems with the windows ..the drivers side goes up but the it comes out of track at top and sticks out i no i need the rubber that goes around it replaced but tnow the passenger door is starting to do it to if i replace the rubber will that fix it or is there more involved like with the window track or what ...any help and suggestiond would be great ...thanks
    "IT IS WHAT IT IS"
    new look courtesy steelbluesleepR
    there is a bolt in the door close to the outside u got to adjust that it will look like it had moved
    current cb 93 10th ann. edition
    member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
      window pin kit
      look for it at the dealership
      MY CB7
      FULL part out thread:
      http://www.cb7tuner.com/vbb/showthread.php?t=204494
        The window pin kit is only for 2 doors. I spent alot of time trying to fix mine. Even went to the stealership and nothing for a 4 door. I lubbed mine up with white lithium grease. It helped but I need to replace the rubber strip.
        -1991 Honda Accord LX H22a-
          lol, i didnt know that
          i guess i learn something new everyday
          MY CB7
            if you look at my sig pic you can see what im talking about right between the door is the black part im talking bout look closely the fron door molding sticks out more than the back door and it right at that section when i put up window that it comes out the track and it leaves a gap there
            "IT IS WHAT IT IS"
              Yeah I didn't know that either and when I went to Honda they acted like I was a jackass.
              With all that glare from the bling bling paint I can't see anything the driver door or passenger door.
                drivers door on the pillar right where the front door and back door meet up the top of window
                "IT IS WHAT IT IS"
                  "IT IS WHAT IT IS"
                    Thats exactly what mine is doing. Is it kinda tearing up that little rubber piece that it goes over? I used some of that grease I was talking about above and it helped. If I use a little every week I doesn't do it but I still need to replace the rubber strip that the window travels threw.
                      ok ill try that but im just like you i need rubber replaced thnx
                      "IT IS WHAT IT IS"
                        Window/track issues are always a PIA
