corroded Screw removal, help?
    i need to remove these screws, and others with as much corrosion, if not more:
    any helpful info is much appreciated.
    My 1992 honda accord LX 5 spd.
    "Behold! What was once thought to have been
    buried beneath the sands of time,
    the ill-fated Haynes Repair Manual has been resurrected
    from the depths of a watery grave." - LX_Accordian
    PB Blaster and vise grips.
    ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
    Project Deerslayer
    UPDATE: DEER - 2, CB7 - 0
    '93 EX 5-speed coupe
    Short ram intake
    Tenrai Himoto catback
    Smashed front end
      you can also take a dremel tool and use the cutting wheel to make a notch, then use a flat head you unscrew it. later.
      Avoiding dirt at all costs
        Don't worry about those until you have the lights off the car.
        wat?
          yeah, true, and since theres always a pair for each, if its a hassle, just replace either one, since those screws are used to hold the lens adjusters and/or brackets, if ever your having a hard time though, but its best to just change it all
          671menace
