I've seen several threads on painting a vehicle, and a couple about repairing damaged paint, but I haven't seen a single one dedicated to taking care of the paint once it's on the car. With that in mind, here's my contribution, stemming from some of my experience in the detail department at a major Harley-Davidson dealership. My two coworkers were guys who had 25 years of experience apiece in detail and recon.
Are automatic car washes really that bad, or can I get away with using them once in awhile?
Using an automatic car wash is probably the single worst thing you can do to your car's paint. Some machines are less horrible than others, but even auto manufacturers are finally conceding the fact that these machines are terrible for your painted finish.
But I can't just not give to charity. Charity car washes are for a good cause!
Then do twice the good deed: give them $5 and wash your car elsewhere. It may be hard to resist young, bikini-clad women with hand-painted signs, but this could end up being the most expensive $5 you ever spend. Think about it: you're giving completely untrained people access to the finish that protects your car from rust, and from looks that say "Man, that paint is horrible!"
Can I use the same cleaner on every surface?
Would you use Ajax to wash your car? Every surface is different, which is why the automotive cleaner section of many stores have different cleaners for the different surfaces. You probably wouldn't want to use wheel cleaner on your paint, and for good reason. Man up and buy the different cleaners for each specific surface. Then you won't have to wonder why your car needs to be repainted two years from now.
OK, so I know a lot of the things NOT to do, so what do I DO?
To start, change your way of thinking about taking care of your car's paint. Instead of thinking of it as a pain in the backside, consider it an investment. You're adding life to your car's painted finish, and saving yourself the cost of repainting every few years. The first thing to do is get yourself the right tools. Here's a good start:
Clay bar - A tip you can live by is to "clay" your paint once or twice a year. You can't see the contaminants left over in your paint, but if you put a latex glove on and ran your hand over your car, you'd feel millions of tiny bumps and bits. A good clay bar will remove and suspend these imperfections, giving you a blank slate to start from. ***Clay will remove the wax from the finish when used - keep this in mind!***
Car wash soap - Never, ever, EVER use dish soap to wash your car. Spend the few dollars to get yourself a decent car wash soap. Other cleaners can strip the wax and damage the car's finish. A good car wash will contain surfuctants to emulsify oil and grease that gets on your paint, and allows you to wash it away fairly easily with water. Also, be sure to use plenty of water in the bucket so that the dirt can settle to the bottom, leaving clean water at the top. Empty the bucket once in awhile and clean it out, then refill it from scratch. This will help avoid scraping leftover dirt and contaminants all over your finish with the washcloth.
Hose - DO NOT use a high-pressure sprayer on your paint. It's just good sense. Do you really want to take the risk of damaging your finish just to save a little time?
Washcloth - Use a sponge or mitt designed for automotive use. Lambswool is a particularly good choice. Clean the mitt when it starts to look a little dirty, and when you change your wash water. This again helps to avoid dragging embedded dirt over your paint.
Washrags - For your tires and wheels. You wouldn't use a mitt that's possibly contaminated with metal filings to wash your car, would you?
Drying towel - Either a good chamois or a 100% cotton terrycloth towel will work best for drying. Chamois cloths are preferred by the pros. If you're in a hurry, you can probably get away with using the California Water Blade or a similar squeegee a couple of times, but if you're not diligent about getting all the dirt off your vehicle, this will drag it over your finish and do more damage than good.
Microfiber cloth - These are great for finishing touches. Some people even use cloth diapers to give their car a buffed look.
Some handy tips for the process:
*Wash your car in a cool, shady area. This will help to avoid water spots and streaking.
*Wash from the top down. The bottom of your car accumulates the most dirt and grime, so avoid dragging this up to the top.
*For stubborn stains and road tar, try using undiluted car wash soap. Let it soak into the stain for 5 minutes or less, then rinse thoroughly with water.
*Clean your washing implements and refresh your washwater frequently.
*Dry the car immediately to avoid waterspotting and streaking.
*Wax as soon as possible afterward. You don't want to give contaminants any time to get onto the finish, because you'll just drag them around your paint and damage the clear coat.
*Try to use paste wax. Spray fast waxes are alright, but there's nothing like a good solid coat of carnuba. You'd be amazed how good it can make your dulled finish look. Remember to use a soft cotton cloth to apply the wax. Soft cotton dishtowels are excellent. (Just don't use the same ones you use for your dishes...)
Taking care of your car's finish takes some time and effort, but isn't it worth it? Don't you want to get that same feeling of pride when looking at your car for years to come, rather than looking at a dull, beat up paint job and thinking "Ugh..."? It takes a lot less effort to CARE for your car's finish than to REPAIR it! Remember that!
