UM i no, i didnt SAY it was te BRIGHTEST, i said thats the brightest ILL put on
H.I.D. questions
do some more research...there's a TON of info out there... BUT you are on the right track...you can't just put the bulbs in...some of the bulbs will glare like shit if you do that...
D2s bulbs blind people because they do not have a shield on them.
I don't know what this "shield is" but that's all I need to know.
Apparently these were designed to be put into a housing much like halogens...I'm assuming this "shield" is not unlike that cap on our halogens...or something...I don't know. Either way...the point I got is DON'T USE THEM!!!
D2r are the ones to use...because they are actual projectors WITH the shield
I've asked a bunch of questions in a thread I made...might help you a little...
http://www.cb7tuner.com/vbb/showthread.php?t=89982____
Originally posted by bcjammerxdo some more research...there's a TON of info out there... BUT you are on the right track...you can't just put the bulbs in...some of the bulbs will glare like shit if you do that...
maybe ill just use them till i find some extra time and money to retro a kit
Watch out for those cement barriers
D2R bulb is on the rightt, you can see the shield. D2S bulb is on the left, intended to be used with a projector housing like the ones on aww_shiet's car.
~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
UPDATE: DEER - 2, CB7 - 0
'93 EX 5-speed coupe
Short ram intake
Tenrai Himoto catback
Smashed front end
i have some ebay plug and play h.i.d.'s, their 8000k's, i installed them about 3 months ago.they only cost about $160.they look great, project great, and yeah they r bright, i dont care about the other drivers, i just care about my sight. the cheap h.i.d.'s arent all that bad, i had some other ebay h.i.d.'s in mi 98 integra they never did me wrong.i guess u just got to do ur home work on they knock offs. and just compare the kits.
but if you install the h.i.d.'s into a projctor housing they work alot better. i hope that helps you out alittle.
