need help installing my sunroof
    hey guys im picking up an oem sunroof full assembly that came of a 90 ex coupe, does anyone know if the mounting holes are there for the none sunroof'd cb's? im gonna be heading to the junkers tomorrow to pick up a new headliner aswell for the sunroof, just wanted to know if somone out there knew if the mounting holes were there
    im assuming if the holes ARE there i can cut the hole, mount the assembly, put in the new headliner call it a day
    goodluck bro lol
    DONT SWEAT THE TECHNIQUE
      Originally posted by birdmanCB7
      goodluck bro lol
      X2... Sunroofs are very hard to do, unless done at the facroty, they leak alot..
      90 Accord EX F22a1 Auto R.I.P.
      2011 Mazda 3 Hatch 2.5L GS sport HELLO!
        I had the same idea before and then looked more into it once i got my wifes accord (with oem sunroof) and said nevermind. for it to exactly like oem you would probably be better off cutting the hole bigger than needed and weld in the trim around the sunroof. cuz the factory roof on the ex with sunroof has a lip that seals the glass. i'll go snap a pic in a sec to show you.
        My Members Ride Thread
          this is looking from the driver side towards passenger side
          this is looking from the back towards the front
          as you can see you would have to bend the sheet metal for the glass to seal right, and there ar 2 drain tubes that run from the assembly through the c pilliars to the rear wheel wells that you would have to run.
            thanks alot for the help but i decided not to go through with this very diffacult attempt lol thanks alot tho!!!!
              yea dont risk it....
              My Cm7
              My Cb7 (DD)
