that would be sweeet if you could do that, i think i found another mod to do to my car
Awesome NEON alternative!
Originally posted by Hijikatahmmmm ill have too check into this, i wonder what color would look good with the stock red/maroon interior. oo i dont know if anyone has seen it before but you can get some pc lights that look like they have water in them so it makes the light look like its shining through water, its pretty sick.
Originally posted by Hijikatawell from what i have understand, there is a light for your ash tray and you i guess splice the cathode light into that, or you just completely wire the cathode into that and forget the ash tray light, ill check this out probably thursday after tropical storm ernesto passes over, unfortunately tomorrows a complete waste cuz this thing is affecting me all day........
Originally posted by increaseBLu3I'd wire it up to a toggle switch so I could turn them on and off whenever I wanted to.
How would I go about doing that? There's gotta be a way!
Originally posted by sirs1ayercan you splice them to the switch for your headlights and shit. so when you turn the lights you turn the cathodes on. because i don't want em runnin when i don't have the lights on pretty much.
i might go look under my car and check.
but can i just splice the wires in for the lights right there after the lever thing?
or do i need to use it somewhere else?
THIS IS WHAT I DID.
the ash tray light, i wired my two fans directly into that wire. got rid of the little ash tray light. if iwant to put it back on, i can. not hard.
the ash tray light is tied in with the interior lights. (dash, cig. lighter, ect.) so whenever i turn my lights on, to that first circle, the fans above my feet come on. it's what i did, very easy to do. if you want pictures, i can/will provide pictures of the actual wiring.
http://www.cb7tuner.com/vbb/showthread.php?t=55157 is what i did. not hard, any questions, post here, or pm me. i'd be more than happy to help as best as i can.
remember, this project is NOT hard at all. just ask questions.Last edited by npor; 08-29-2006, 11:50 PM.
Originally posted by nporare you talking about having them powered 24/7? or just when your lights are on, and having the ability to have your lights on, but the cathodes off?
But I like the idea of having them tied to the ash tray light, only I don't have an ash tray light, lol. I don't think mines works. Is there another way to do that? Cuz it'd be cool to just turn the headlight knob to the first setting and have the lights on. I'd be down for that.
Definitly would also like pictures of the wiring, please!!!Last edited by increaseBLu3; 08-30-2006, 10:10 AM.
alright man, this is what i can do for you.
since i've got to be at work in about 25 minutes, i can't do anything as of now. except get ready for work.
so, at work, i'll be thinking of ways you could wire them. then, when i get home, i can take pictures of how i wired mine.
an option you can choose is splice the wire to your cig. lighter. but there's like 4-5 wires that that confused the shit out of me, so that's why i went with the ash tray light.
p.s. thoes wheels on your car are tight, drop the car and it's gonna look tight as hellll. also, if you're thinking of getting new tail lights, try to smoke them first, see how they turn out.
just a little suggestion :-p
but yeah, i'll get back to you when i get home.
Alright buddy,
Here is what you need to do- There are hundreds (well, maybe not) of live wires that run thoughout the car. You can use a live ignition wire (I wouldn't) the light from a cigarette lighter (good option) the constant power source to the radio (good option as well) or last but not least directly to the battery. (Lots of messy wires, so I wouldn't do this either.)
If you want to maintain the integrity of the wires, 3M (The Company) makes these groovey things called T-Taps that you peel back the insulation with a razor, put it over the wire, and don't have to cut. So from your live wire you take it to the switch then to the individual lights (two wires) then ground the lights.
Bulldog Security makes crappy alarms but has a free vehicle wiring diagram, so you can look for the various live power wires.
The reason you use a constant is so you can use them when the car is off, if you use a switched power, you would have to only use them in accessory or when the engine was on.
So:
[Live Wire]--------[+swich-]---------[light power wire]-----[chassis ground]
---------[light power wire]------[chassis ground]
Unless I screwed something up you should be good to go.Why? Because... Life Happens @ 4500 RPM
Frost White CB7 Member 31
