diy $3.60 short shifter..
    i just removed the console, this includes the part around your e-brake.
    4 bolts total. Then took the shift knob off and the rest is kinda obvious.
    un mount the cable where its existing, and thread your leading bolt through it about an inch or so up. clamp the rear bolt down real tight and reassemble!
      do they not make a short shifter for the cb7...
        not specifically. the prelude one can be made to work.
        I'm sure on ebay you can get some shifter bars that are shorter and have the mount welded lower as well.
        But why pay 50-100 + when you do it yourself for under $5? Plus, you won't see the hardware when you put the boot back on...so who needs a pretty part that is never seen ever
        ____
          i've drove my old accord where i had done this, and fo4r the price it's pretty ok.
          but when i had baught a PSpec short throw shifter, their really was no comparisson in the difference, pspec shifters are just emaculately tight and smooth. I like their weighted handle that can be baught with the kit as well.
          "Self Renewed"
            diy short shift
            This works great I wish I had thought of it 4.00 and 10 minutes kudos
              Im totally doing this!
              You see models at every car show.
              But have you ever seen a model that actually takes the car she built to a show?
                this is being done tomorrow i love the idea. i will post pics of before and after
                  im doing mine tonight too! haha.
                  Ill post pics
                    did it yesterday n cost like 5.40 or sumthin
                    it slipped off but added a washer and bent it and locked it :]
                    all good for a 100 mile drive thru riverside last night
                    LOWES RACING FTW!
                    .My Ride.
                      srry for no pics guys, but i did do it. and it works awesome. pics will be up soon
                        thanks ill be doing this tommorrow
                        1992 Accord Cb7:
                          I did it as well... cost like $7 (inflation i guess) but works like a charm!
                            man i might have trouble doing this
                            1992 Accord Cb7:
                              if you have trouble just ask cause its not that bad at all.... undo the six screws that hold the center console down. then undo the nut that hold the shifting linkage. install the ground connector thing and then bolt the linkage to the ground connector and reinstall center console
                                just did this today, not a bad little mod. fun too!
                                Pros: feels tight
                                short throw
                                solid
                                fun
                                cheap
                                Cons:rubs interior of center console
                                cheap
                                overall, worth it if your a cheap ass like myself lol. i think this will do until i work on something a little nicer like a prelude setup or forbidden shifter if i can find one.
                                if you attempt this, make sure to buy fender washers so the cable wont slip off the rubber bushing, that happened to me while i test drove it.
                                enjoy.
                                1992 Accord EX MT : CB#2
                                DIY OEM amber corners w/reflectors
