What's the best rim size for a 91 LX? I have 14"s right now and I'm not sure if I need to go 17"s or maybe higher. I also want to improve my handling through turns ar high speed and stabilize the car after 115 mph+ because afterwards it starts shaking a little. Does anyone have any products in mind?
Wheels and Suspension
Originally posted by arthaccordget some 16'' rota slips with a 215 55 and it will look good and handle good'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Originally posted by Joey GT-RI'm a little new to the scene so english please? rota slips? And what are the measurements for the 215 55? What I want for my car is for the wheel wells to be filled up a little more, and for the car to have improved handling. I'm not really looking for a drop, I mean really I'm neutral on the whole lower ride idea so if the wells are filled up and the car handles better then so be it. And I want the ride to be just as smooth as it is stock or better.
i have 205-40-17's and i think the handling and ride is better than that of the 205-60 -15 rims i had on it in the first place...if i were to get other wheels i probably would go 16 inch a bit wider and higher...maybe 205-50-16? i think they would look ok and ride a bit better and handle about the same....or how about 215-50-16? i wonder how they would look...
Originally posted by Joey GT-RFunny how I can't "Test-Drive" all these combos..... So let me get this straight I get 17"s drop it slightly and I shouldn't compromise the ride right?
click on the link below.
Easy Button
ride comfort usually depends mostly on tire profile (higher being better-thicker sidewall) and softer springs (usually taller-shorter springs have to be harder to have less travel since they are shorter)
so get a 2" drop on some soft springs
eibach sportlines...closest to OEM drop..i love mine..so smooth
