Sunroof swap
    I replaced the sunroof in my 93 SE because the glass detached from the frame and I could not find a glass shop to cut me a glass slab the same dimensions.
    Replacing the whole unit was a fucking nightmare.
    It was fine for 2 years in the end but then it too started leaking and I always have a sunroof.
    Just find a cb with one already, its the easiest.
      I've removed a sunroof before it's really not that complicated just a little time consuming. I just want to see what my options are as far as sealing the hole on the roof in a way that doesn't look like.... crap.
        I'm afraid you're outta luck. All the sunroof deletes i've seen just look downright crap. Your best bet is changing the roof skin if you want the best look
