I recently purchased a TCS Portline carbon fiber hood. I was afraid of the quality seems how its $200 cheaper than Sibon and most of the other brands. As far as I can tell it is a quality hood. It looks great. I was smart enough to take the weather stripping off of my stock hood but I'm not sure how to attach it to my carbon hood. It was attached to my stock hood with plastic grommets. I don't want to drill a bunch of holes in my new hood. I was thinking about some 3M double sided tape or some sort of silicone. I tried rubber cement but it didn't work. Another question, I don't think I'm going to be doing any high speed racing. Are hood pins really important???
carbon fiber hood question
http://seiboncarbon.com/support/
Are hood pins required?
Yes. Although most of our hoods come with built-in latches (depending on whether or not your stock hood has built-in latches), hood pins are required for your own safety.
3M tape should work just fine.
Depending on how securely the hood latches, and how strongly the latch loop is attached to the hood, it might be alright to run without hood pins. I had a carbon fiber hood on my car (I forget the brand... it was a decent brand, though), and I never ran hood pins. The latch loop was thicker than stock (requiring me to modify the latch to fit), and it was on there very securely... so that hood went nowhere!
Keep in mind that you don't have to be "high speed racing" for the hood to come loose. If it's not secure, it can pop up at a relatively low speed. Even at 35mph, that hood could fly up hard enough to shatter your windshield and seriously damage your roof. It could also make you crash. Use your head when determining whether or not you can get away without pins.
