I have a 92 EX sedan with SRS.The foam that makes up the steering wheel has come loose from the internal metal ring.I was wondering if anyone had a fix or somehow removed,refoamed,and wrapped their steering wheel.I'm not sure what to do because I can't find a good steering wheel with SRS and cruise control.
Steering wheel covering issue.
upgrade to an Acura Vigor (92-94) leather wrapped wheel. It'll bolt right on and the cruise control will as well. It also has a cancel button on it that'll plug and play directly to the CB's connector.
member's ride thread
91 Accord SE 176k
Originally posted by Corweena View Post^ that would be a good option.
Can S2000 wheels be used on CBs? I know they can fit on CDs, and I figured they might on CDs. Because they are one of the best OEm wheels in my opinion, and really spruce up the interior of the car.
91 Accord SE 176k
The foam has come loose from the steel ring that makes up the steering wheel.Wrapping it won't stop it from twisting and sliding on the ring.Using any form of super glues will dissolve the foam.I can't find any CB7 wheels here that are in good condition and swapping to an OBDII wheel is out of the question.This car is going back to stock from being hacked up.I'm trying to prevent more problems from cropping up by modifying the car.once the car is back to factory standards, and running properly,I'll consider mods.
Originally posted by EscCtrl View PostThe foam has come loose from the steel ring that makes up the steering wheel.Wrapping it won't stop it from twisting and sliding on the ring.Using any form of super glues will dissolve the foam.I can't find any CB7 wheels here that are in good condition and swapping to an OBDII wheel is out of the question.This car is going back to stock from being hacked up.I'm trying to prevent more problems from cropping up by modifying the car.once the car is back to factory standards, and running properly,I'll consider mods.
