My driver side window rolls down fine, but when I roll it up, it gets off track, and juts out of line, creating a gap in the door and the glass. I think it's my window regulator, but I'm not sure.
What's wrong with my window?
Originally posted by dysfunk View PostMost likely the window sash and the weather stripping by the mirror. Thats my issue with mine.Originally posted by Quashishhahaha
noobs be like where to be buying hella flush yo?
Originally posted by '93CB7Ex View Postpull the panel off and look to see if the bolts that hold the glass to the regulator are tight. also, check the bolts holding the regulator to the door frame.Originally posted by Quashishhahaha
Originally posted by deevergote View PostUndo all screws on the panel, then pop it off.
It's the regulator. There's a plastic bit that breaks off, and what you have happening is the result.Originally posted by Quashishhahaha
New regulator, unfortunately. They're not terribly expensive, thankfully. Rockauto has them. ********* probably does as well.
I have to replace mine, in fact.
Be careful when installing. Be sure to adjust it properly, and be sure the bolts are tight. I didn't adjust mine properly, and the two center bolts came loose. They sawed their way through the metal on my door, ruining the mounting holes. I may need to get a new door to ever have a properly functioning window (which means ANOTHER paint job!) I blamed the cheap part at first, but I think the reason was probably my careless installation.
Also, if you want to lubricate your window tracks, use powdered graphite. Don't use any petroleum or silicone based spray. Also, don't clean the "dirt" off the sides of the window glass. That's graphite. It's supposed to be there. (again, speaking from personal experience!)
If you have a kragen or O'riley's in your area they sell you a new or refurbished motor and regulator has a lifetime warranty.
C-3PO's MRT USDM yo!
Originally posted by deevergote View PostNew regulator, unfortunately. They're not terribly expensive, thankfully. Rockauto has them. ********* probably does as well.
Also, if you want to lubricate your window tracks, use powdered graphite. Don't use any petroleum or silicone based spray. Also, don't clean the "dirt" off the sides of the window glass. That's graphite. It's supposed to be there. (again, speaking from personal experience!)Originally posted by Quashishhahaha
It is possible to remove the plastic part from the regulator. I have had to do that on my rear windows when they had the same issue you are having. I went to the junkyard and removed the plastic parts from cars there and then replaced mine with them. Cost me $5 at my yard for 4 of them. Possible alternative for you if you cant or dont want to afford a whole new regulator. Need to take some caution though cause you can break them taking them off and on.
take a picture of the weather stripping next to the mirror.. that's where my issue is.. and from the looks of it, could be your issue as well.
Mine still pops out of the track even after replacing the motor and regulator.. by the way, i bought both, for 51 bucks shipped.92 Honda Accord LX - Sold
2005 Nissan Altima 2.5S - Sold
2007 Dodge Charger SXT
When I got my white DD accord it was doing hte same hting, part of the weather stripping and window guide was missing
Regulator was fine, a trip to the local Pull-A-Part took care of it.-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-2012 GMC Canyon V8 4x4
