Originally posted by N9netwoAccord
View Post
Couple questions about wheels and fitment.
Originally posted by BigJakecb9 View PostI just got some apache 2 Wheels 15x8 +25 they just stick out a little bit but im alot lower than 2 inch drop. You should probably do like17x7 +38, its would look good with a 2 Inch drop
Originally posted by oni_cb7 View PostIt would be closer to the fender and it depends on how wide the rims are. If you look through the member's rides threads then you should be able to find images of cars with the rims sizes that you want.
Originally posted by BigJakecb9 View PostLol I'm suprised your the first person to mention that the op is getting skunks.
Originally posted by deevergote View PostSo basically, you want to look like every other retard on the road with poked low-offset small diameter wheels? Planning to run crazy negative camber as well?
Learn to use the "edit" button when you want to add something, or you're going to find your post count set back to 0.
Originally posted by N9netwoAccord View PostI'm not quite sure you understand what torque steer is
