In your opinion which is the best bulb (haha stupid autocorrect) to use performance wise, and what heat for hid?
quick question on retro fitting jdm one piece headlight
Not to mention that when she goes running with you all of the other guys will be looking at her jumbly bits.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
I was referring to boobs.
Honestly, it doesn't matter which bulb you get these days. Even the cheapies seem to work fine, and the cost is low enough that replacing them won't kill your wallet. The only thing to keep in mind with the retrofit is that JDM lights are a bit tighter than the USDM glass ones, so some projectors that fit in the USDMs may not fit in the JDMs.
I'll move this back to the appearance section now that we're no longer talking about boobs...
If it affects the way your car looks, post it here. If it affects the way your car performs, post in the performance/technical section. If it has to do with your stereo, alarm, or other electronics, post in the audio/electronics section.
Shut off means nothing. Cut off means the point where the light stops. HIDs are prized for having a sharp cut off. Not glare bleeding all over the place.
I was looking for good cutoff pictures, and I came across this. This will explain a lot, and illustrate the cutoff quite well at the same time:
http://articles.dashzracing.com/car-...10000k-12000k/
As far as "heat" then that up to you... The higher the kelvin rating the more colorful (and in most instances more useless) your output will be. Personally, I wouldn't go anywhere past 6000k. 4300k is what I would use actually.
And you won't need to worry about your cutoff, from what your saying it sounds like you plan on using your stock housing for the HID. If you do a projector retrofit then cutoff is important.
Originally posted by deevergote View PostIf it affects the way your car looks, post it here. If it affects the way your car performs, post in the performance/technical section. If it has to do with your stereo, alarm, or other electronics, post in the audio/electronics section.
Philips 85112+ or non-plus. Best bang for your buck IMO. Pretty much the standard in D2S bulbs. Only comes in 4300k. The + version stays true to the 4.3k color. White with a hint of yellow. The non-plus has a color shift from 4.3k-5k sometimes 6k later in the bulb's life.
Philips 85122+ 4.3k:
Originally posted by Function>Form View PostPhilips 85112+ or non-plus. Best bang for your buck IMO. Pretty much the standard in D2S bulbs. Only comes in 4300k. The + version stays true to the 4.3k color. White with a hint of yellow. The non-plus has a color shift from 4.3k-5k sometimes 6k later in the bulb's life.
Deevergote thanks for the link
Originally posted by curlyboy07 View Post...I just havent quite understood what a lot of the terms mean so i'm trying to get answers from other people that have done it so it can help me understand better, I read a couple diy but still don't understand what some things are...
