My door unlock/ lock latch came off i tried to fix it but couldn't.. i need help
door latch
Originally posted by HardInThePaint View PostWhat are you talking about the actual lock/unlock button or where you put the key in? And is it the entire handle or what?Keep It Low, And Drive It Slow
89 CRX dx with a 94 del so Si swap - deceased 91 civic hatchback Si with a JDM ZC SOHC swap-sold 92 CB7 accord sedan - living but stock
You have to open up your inside door panel. You will see the door latch there from the inside, there is a rod that connects to it that moves when the key is turned and locks/unlocks the door. That rod probably came out, I believe its held in there with a c shaped clip or with a piece of plastic that clips to the rod and then to the handle (or maybe both I can't recall really). Regardless, somewhere in the mechanics involving that rod might be your problem, like I said though you have to open up the door panel to access all of that.
