Front Tow Hook
    Front Tow Hook
    I am thinking about making a front tow hook for my car but not sure how to install it right and how strong it would be? has anybody installed one theirself, and any DIY?
    Check out my MRT: http://www.cb7tuner.com/vbb/showthread.php?t=189190
    well there is no "safe and functional" way to install a front tow hook so you must take off your bumper and bolt it straight on to your plastic (very thick) bumper support....It will be for looks only though! You'd have to use your OEM front tow hooks if you ever do need to use them.
    KEEP IT NICE, NOT RICE
      Alex pretty much said it all right there and answered it
      http://www.cb7tuner.com/vbb/showthread.php?t=189897 MRT
      http://www.cb7tuner.com/vbb/showthre...09#post3003309 EF hatch build
        thank you sir
        and good luck with the install!
          i didnt know it had an OEM tow hook. where is it at and whats it look like?
            Heres my home made real tow hooks.
            http://www.cb7tuner.com/vbb/showthread.php?t=184596
              Nice!! thanks for the link NightmareCB7!! now thats what im gunna make instead
                Your welcome.
                They are made for work. I have used them to pull cars and the bumper back out on a friends truck too.
                  There is no OEM "tow hook" in the same sense as the ones people install. The hooks on your car are not there to pull the car out of a ditch, or tow it down the road. They are there to strap the car down to a towtruck.
                  The only way to make a truly functional front tow hook is to devise a way to mount it securely, as NightmareCB7 did. Anything else is merely cosmetic... and in my opinion, laughable. A tow hook screwed to your plastic bumper is just as comedic as a "turbo" badge on a non-turbo car, a hood scoop that doesn't actually go through the hood, or hubcaps made to look like rims.
                    yeah i looked under my car and found them.. those are useless!!
                      For what they were designed for, they're quite useful. Far more useful than a tow hook screwed to a plastic bumper
                        yeah i am going to make the tow hook and weld it onto the OEM tow hook so hopefully it will be very strong!
