I want to control my music thru my steering wheel can I put he 2008 or 2009 steering wheel in my cb7 and if so what are the requirments?
steering wheel swap
This topic is closed.
As for the splined mounting portion of the wheel you can either see if the CD5 steering column matches the wheel you want or do what lucifer1 did and weld the CB7 splined portion onto the framework of the new wheel.
As for the wiring; if you have to ask you can't do it.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Jarrett View PostAs for the wiring; if you have to ask you can't do it.
Thats just like somebody asking, "How do I blackhouse my headlights?" and u saying, "If you have to ask you can't do it." Thats not even answering the question.
No, we're not talking about headlights in an oven and a can of paint. What the original poster is asking for is directions to wire the controls for an unknown steering wheel, with the only conditions being that it come from a 2008 or 2009 car, to an also unknown head unit. There are kits you can get to adapt to certain head units but you have to understand a wiring diagram for a car that the wheel comes out of and his own that it's going into. But if you'd prefer that I spoon-fed you directions instead of giving you honest truth, then I can arrange that.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
He's asking about a custom wiring project... that would require wiring diagrams for the head unit and the steering wheel, as well as a fair knowledge of electrical systems. So I agree with Jarrett... nobody is going to teach him how to do all that custom work in a thread on a forum. It's simply not possible.
YungTigger, there will be nothing to simply plug in. As mentioned, there may not even be a wheel with stereo controls that has matching splines, so you'd need to do welding. If you can't weld or wire, then this project has just hit a wall. Learn those things first, then we can discuss the necessary steps.
If you want to do it the easy way, get a head unit with a remote, and tape the remote to the steering wheel. Or, if you want to get creative, and you want to learn how to use fiberglass... disassemble that remote so that you can relocate the buttons while retaining functionality. Do some creative fiberglass work to replace the inner portion of your steering wheel (easier with a non-SRS wheel) that has integrated radio control buttons that come from that remote. Honestly, that would probably be easier to do than what you're asking.
Originally posted by deevergote View PostIf you want to do it the easy way, get a head unit with a remote, and tape the remote to the steering wheel. Or, if you want to get creative, and you want to learn how to use fiberglass... disassemble that remote so that you can relocate the buttons while retaining functionality. Do some creative fiberglass work to replace the inner portion of your steering wheel (easier with a non-SRS wheel) that has integrated radio control buttons that come from that remote. Honestly, that would probably be easier to do than what you're asking.
Originally posted by HardInThePaint View PostThat sounds all good but its still ignorant to assume he can't do it just because he's asking how to do it. Thats all I'm saying.
To add some value back here the most work I've found on the subject has been done by lucifer1. He's very proficient with wiring and I've asked him a few questions myself when I've done wiring projects involving modern Honda switches. These are both his threads where he documents his work.
Radio controls another way:
http://www.cb7tuner.com/vbb/showthread.php?t=184819
Steering wheel retrofit:
http://www.cb7tuner.com/vbb/showthread.php?t=148087My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
A simple search shows you don't even have to change the steering wheel to steering wheel controls
http://www.cb7tuner.com/vbb/showthre...ering+controls
how to put a newer steering wheel in
http://www.cb7tuner.com/vbb/showthread.php?t=148087Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
Originally posted by Jarrett View PostI know you're being facetious but I would like to add that changing batteries in that remote would be a bear!
Haha lucifer! I beat you at your own game. Muah-hahaha!My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
You would not need a battery. Just wire in a voltage regulator to the back feed 12v of the horn relay
Yes you beat me, damn ipad shut down and lost what I was typingManual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
you would need the steering wheel, headunit, and pigtails for it all to work together. you cant just bolt on a steering wheel on and have the buttons work
the new honda steering wheels look out of place in out chassis as well. its like putting stainless steel modern appliances in a plantation home.
it is possible for you to do it and make it work dont get me wrong but its alot of custom work and you will have to answer your own questions as there is not a DIY for it or anything close to it. i would focus on installing the headunit first THEN move on to the wheel.
Originally posted by lucifer1 View PostYou would not need a battery. Just wire in a voltage regulator to the back feed 12v of the horn relay
Originally posted by Jarrett View PostIt's not ignorant.
...and we're done here.
HardInThePaint, if you want someone to take you seriously, type like a big boy. You may have a point, but even I can't bring myself to bother understanding your argument when it's filled with "U".
And to be quite honest, if he knew how to wire and fabricate, he wouldn't be asking... he'd be posting a thread showing us that he's already done it.
If you don't know how to do an H22 swap, but you know your way around motors in general, your questions will USUALLY be a bit more focused than "can I do it?"
