What can i use to removal it i think i tried everything? still cant get it to come off any suggestions?
Interior upholstery glue removal
i used a razor blade and scraped it off.
Originally posted by keepinitcleanI give it 2 weeks before you sell it.
also if your gonna replace the fabrick just cut the section out and glue the fabric to the foam... just another idea
I also recommend sanding it off. Use 120 grit to start, then finish with 180 grit. In the process of re-doing my door panels I found that it just makes a huge mess to use an adhesive remover like the aerosol can of 3M Adhesive Remover we use at work to clean double sided tape off of mouldings. It just gets snotty, stringy, and makes a huge mess. The glue should be old enough that sanding it off will be quick work.
The rug on my door panels peeled off and i have the ugly glue exposed, one day i accidently sprayed the glue with brake part cleaner and when i tried wiping it off the glue came right off...i havent done the whole panel in fear or ruining the plastic but so far it stilll holds it shape and color.Last edited by JaberCB7; 05-25-2011, 10:28 AM.
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Adhesive Remover Wipes
QTEK Manufacturing Ltd. is a leading global manufacturer of consumables for the electronics and associated industries.Qtek offers adhesive removers which Removes misprinted adhesives and pastes before they cure and attach themselves to screens or PCBs.Strong, yet non-destructive cleaning product, fast evaporating and odour-free.Ideal accompaniment to in-line cleaning systems where adhesives are dispensed.Available in tubs of 100 pre-saturated wipes and 100-wipe refill packs
www.qtek.com
