i want to paint my valve cover what is a good temp and time to put it in the oven.
valve cover painting
Why not just get it powder coated?1991 Accord Ex - H22A - Omnipower Coilovers - Greddy SP2
1993 Civic Dx - D15B7 - T3/T04E - Ported head - Hole in block - May be going F swap
My Workout Log
Originally posted by LeungWell, I poked the big one in the head with the shovel while shouting at it "hey, you can't sleep here".
You are not really explaining your self right, you want to paint your valve cover, and what to put it in the oven?? Ok, what is the main question?
How long should i put the valve cover after painting it in the oven to cure the paint?
or what color and type and brand should i get?
______________________________
"I ran open header once, it was sooooo loud little kids were running for cover as I was cruising at 2000rpms. That was enough to know I shouldn't floor it."
Get 500 degree paint. Prep and dont use the oven. No point.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
if you go to your local hardware/auto parts store you should be able to find a good high temp paint that won't require you to bake it. if you are completely stumped with how to go about painting your valve cover here is a pretty good step by step write up.
http://www.instructables.com/id/How-...e-Cover/#step1
This may be a bit advanced for those who use that previous link, but you can also check out this local thread.
http://www.cb7tuner.com/vbb/showthread.php?t=84182"Self Renewed"
Originally posted by KeeleDesign View PostThis may be a bit advanced for those who use that previous link, but you can also check out this local thread.
Originally posted by KeeleDesign View PostSeriously you don't want those fumes in your home, They will linger forever, and really are not worth the health risk.
A good curing in the natural sunlight is good enough for most products, except powder coating.
1990 Honda Accord Sedan
1998 'Slammed' Ford Crown Victoria LX
