Wheels-Offset
    Wheels-Offset
    How do i determine the right offset for wheels?
    you dont determine the offset for a set of wheels unless your piecing together multiple piece wheels with different barrels.
    if you want to figure out what offset to look for when buying a new set of wheels, find out what size wheel your looking at, a figure out how much back spacing you want. use stock wheels as a basis to figure out what your looking for.
    or, do it the easy way, and look at members ride threads and figure out what kind of look you want. then ask for the wheel/tire specs and find something comparable.
      i believe you want to be in range 38''-42''
        What kind of look are you going for? My suggestion would be to check out rimtuck.com.
        Or, like what Flatline said, use your stock wheels as a base to figure out the offsets and sizing you want. You can also play around with different sized spacers first to help you out. This is exactly what I had done with the BMW
        On my BMW:
        17x9 ET +9 all around w/ 215/40/17 Falken FK452s (One of the best tires to stretch)...you can also see the set of spacers I used with my stock wheels to determine the right offsets.
        Uploaded with ImageShack.us
          off topic, but your ass better be posting more pics of that beamer....
          but seriously, find out what look you want before anything. that'll get you the closest. then its trail and error for camber settings, ride height, and tire/rim size/stretch and so on.
            flush i think would be what im going for.
              there are different grades and levels of "Flush". unless you literally mean flush at which point you want the rim edge to line up with the fender almost perfectly.
              either way, find some numbers that get the look you want. then search for similar wheel stats. Its really not very hard.
                Well it might not be hard but it sure was easy to buy the wrong kind my first time around haha.
