Corner Light Removal With Bumper?
    Ive been searching around and theres alot of DIY's on bumper and headlight removal with corners as well, but im just wondering if you can remove the corner lights and put in a new set without having to take the bumper off? thanks in advance.
    from what i understand i dont think you need to remove the bumper just to take out the corner lights, same goes with the bumper lights...
      Yes.
      1.) Open the hood.
      2.) Remove the 2 screws on the top of the corner light.
      3.) Remove the 2 plugs from back of corner light (twist and pull).
      4.) Reverse steps to install new ones.
        thanks i did it today with the blackhouse DIY, but my corner lights dont work, they didnt work before i switched them either. the plug that goes into the bulbs (idk the proper term) looks really reallly old and ..like rusty? sorry, im new to lighting and wiring. what is the problem? and whats the solution..? thanks!
          hey man its corroded (not a good speller), easiest thing is to go to a junkyard and cut off some that look good n solder them to ur cables.
            He si right. Try first with kind a contact spray. It's not a permanently solution but may help for a while.
            It's recommended, time to time, to spray all contacts to avoid corrosion.
              great comment +1. contact spray may possible help the OP. i have freed up snap plus with it before . good luck OP.
                If the part where the bulb goes in is corroded then get a new one
                that peice has a connector in the back of it
                Also pull the corner lights out FORWARD, i tried at an angle and broke them...
                  sweet thanks for all the help guys! yeah, i always wondered why i saw members on here with their corner lights on, and yet mine never lit up..
