Safe Paint Removal??
    Ok, So a Buddy of mine Decided to rattle Can Paint his CB Black, and now Regrets the Fact that it dosent look So Great, Now my ?'n is. Is there any safe way to remove the black paint without damaging the Oem Seattle Silver Paint that lies underneath?? (Ooh and the was no prep work prior to the rattle Can)
    Thnx in Advanced
    lol, well that sounds like it was the biggest waste of time and effort.
    I'm going to say use lacquer thinner, and pour it on and wipe it off, ONE PANEL at a time, and immediately wash the panel with soap and water. Don't rub too hard with it or it will begin to eat into the clear coat.
    Does he have plans to maybe paint the car again? You could scuff it and just hit the whole car with high fill primer and sealer.
    He can rattle can the entire car for about $100 worth of paint and prep material, and 2 days.
    Example of $100 rattle can paint job in 2 days.
      Wooow!! Those are some pretty nice Results , What kind of thinner/Laquer would you recomend and any specific method needed?
        I dont know what's available in the states, but I use the brand Home Hardware sells here. Basically pour it on a rag or paper towel and start to rub. The paint will start to come off.
        I've used lacquer thinner ontop of my factory paint before and I haven't had any issues. It will literally eat right through the spray paint, and shouldn't harm your stock paint. But like I said, make sure you wash it with soap and water immediately.
          he probably would have been alot happier if he did prep it first by sanding but just saying rite now if he does use lacquer thinner or pretty much anything if there was any clear on the paint before its pretty much guarenteed to get some damage in areas and dam thats gonna be alotta work gettin it of alot more than rattle caning it on thats for sure
          in the begining...
            i would hate to say it but hes kinda screwed..try the thinner. If it goes through to the clear. Sand it all down and spray it again.
            If you look in my "newb" thread with my cars my notch is sprayed in flat black with a can. That was not taking my time. TAke your time with it and do it in nice weather.
