Ok I have a 91 accord 4 door. I am gonna drop it two inch and put on some rims. But with a 2 inch drop whats the biggest rim I can put on i'm thinking like a 17 with a 45 series tire will that fit?
What rims will fit
yes 17s will fit. Im not sure about 45s but i know 40s will fit. I know a guy that has 18s on a 3inch drop
Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
Be sure to get the proper offset, as that will make a difference.
You may have to remove the plastic splash guard in the fenderwell, or you may rub it when making tight turns. I did with less than 2" on 205/40/17 Falken Ziex 512 on 7.5" wide Falken Hanabis... I can't remember if the offset was +38 or +42.
Originally posted by andrew22888 View PostBut what is offset explain a little more.
Originally posted by andrew22888 View PostOk this is exactly why i'm in the beginner section lol. But what is offset explain a little more. And if by splash guard you mean the mud flap things then they are already off.
The splash shields I'm referring to are the plastic sheets that go under the fender. Look in your wheel well. Knock on the part that sits above and in front of the tire. If it's plastic, that's what I'm talking about. If it's not, then they may already be off.
so basically from the center of the rim to the lugs where it contacts the hub correct. Also even if I get deep dish rims can you still get different offsets on deep dish rims. Sorry I just don't wanna mess anything up. And also I read the thread lowering FAQ 101 and I wanted to do the H&R springs and the Bilstein struts. But I can't find them anywhere. Does this site have like a parts website that alot of this stuff can be found.
what kind of chamber, if any, should i expect
if choose to have a 2" drop on 18x7.5 +40 on 215/40/18?Last edited by jewelproject; 03-23-2012, 05:49 PM.RIP 4/23/12...lets not forget, the 88" Z31 turbo, are my dailys
I'm rubbing on a 3" drop with F&F Type Is. I seriously need to invest in some newer ones with damper adjustment. Damn regular maintenance is taking my money.
I'm on 18 x 8 OEM Acura TL wheels with 215/45/17 tires and a +45 offset, I believe.The Lord watches over me!
"Stop punching down on my people!!!"
- D. Chappelle
