Do most people put their speakers back in the original speaker boxes above the trunk? I took them off and cut the speaker to fit. Now i don't like the way it looks so i found some boxes at the junk yard and put the speakers back in them. Unfortunately i have about a 1"x2" hole on each side of them where i cut to make the speakers themselves fit. Is there a way i can install that back material myself? I saw plenty of it at the junk yard! OR is there some other way to do it?(different set up of rear speakers.)
Rear speaker placement.
Originally posted by fi2hm View PostYea i mounted the 6x9"s without the box. Now i put them back i the box.
Sorry I'm a little confused.
If you cut your deck, you can easily remove it and swap in another one from the junkyard. Coupes and sedans have the same deck, so the donor car does not matter. If you've broken the clips while removing your deck, you can use velcro to secure it rather than getting more clips.
Same goes with swapping the speaker pods. If you originally had 6.5" pods, you can get a pair of 6x9" pods and use them with your new 6x9 speakers.My pictures/photos will return soon...
Originally posted by Joshy View PostDid you originally have 6.5" pods and cut into the pods? Or you cut into the deck and didn't use the pods?
Ah! I see.
When you cut into the metal, did you eliminate the speaker pod mounting holes? Do you still have the metal pieces you cut out?
You might be able to JB Weld the metal back to the deck, if it's at all salvageable. If not, you could get some sheet metal strapping and use it to somehow re-secure the speaker pods to the deck.My pictures/photos will return soon...
