how to remove water spots?
    i had this problem once i went to a part store and grabed some 1500 grit wet sand paper and wet sanded the glass n it worked pretty good..just in case u see screatches from the 1500gp id go over it with 2000gp but 1500gp worked fine for me..good luck
      Originally posted by DunKrS View Post
      Straight Rain-X actually took the spots off my car. I was really surprised. That stuff probably cures cancer too. Maybe even Aids...
      This didn't remove my waterspots but it WILL keep you from ever getting them again as long as you keep it applied somewhat constant. I do Rain-X after everytime I wash my car. I LOVE it, especially living in the rainy state.
        Just try clay...Go get some from your local Autozone...It works good on your car and windows...
        My signature was removed because it was too big.
          What about using these products on paint? My glass is fine, but my paint is covered in hard water spots. Also I figure the paint wont react the same to glass... Unless im wrong.
          MYCB7.com
            on paint i would say it depends on ur clear coat..u can probobly buff all the water spots out. careful not to burn thrugh the clear tho
              For your paint, I would probably use a claybar. I have yet to see if this works, but I have waterspots on my car that I'm going to try claybarring soon. You'd be surprised how much claybarring removes though.
                This is the best for the job... http://cgi.ebay.com/BIO-CLEAN-WATER-...item1e5f101b92
                  If used like instructed...Clay bar works magics bro...Remember use a clay bar n the matching lubricant...Idk if you already know that or not...But just throwing it out there if you don't already know...And also if you use it don't push hard...I scratched my paint doing that...And I thought I passed that on...Since I didn't know and now I do...Hopefully you bring you paint back to life...And Good Luck...
                    I waxed all my windows inside and out. When they fog up its 100% even and no water spots. As well as its amazing in the rain.
                      Originally posted by F22HB View Post
                      Tree sap
                      XD almost as bad as pollen, thank god pollen washes off.
