How do you get the back seats out from 90 coupe its has a lock for it but i dont seem to have the key and i need it out for my custom layout that i did 4 my speakers any ideas ???
backseat help!!
pop your trunk, and directly behind the seat under the panel where your rear speakers are, there is a pull handle that manually releases the rear seat lock. Pull that handle, and push the seat back forward. There will be two bolts holding the seat back section in the car. I believe they are 12mm. At least in a sedan (not sure about coupe) once the seat back is removed, the seat bottom will fold forward and then you can pick it up and remove it from the rear of the car. Hope this helps.
The coupe is exactly the same as the sedan
By the way the key is the same key as your ignition, provided your key works everything else in your car then the lock is most likely just jammed. It seems to happen alot, both my mine and my brothers jam some times. The only real way to unjam it is to open the seat up with the method provided above.
Originally posted by rob_is_legend View Postpop your trunk, and directly behind the seat under the panel where your rear speakers are, there is a pull handle that manually releases the rear seat lock. Pull that handle, and push the seat back forward. There will be two bolts holding the seat back section in the car. I believe they are 12mm. At least in a sedan (not sure about coupe) once the seat back is removed, the seat bottom will fold forward and then you can pick it up and remove it from the rear of the car. Hope this helps.
