Rear Lip Help
    Rear Lip Help
    How do you install the rear lips that are sold online
    xenon for instance?
    do you have to cut the oem molded lip or what?
    ^^MRT^^
    THIRD EYE FISH
    you cut off half of your bumper then you goto honda and purchase 3512-sm4-5612 adhesive. The adhesive is made for lips for the accord.
      you have to cut along the line where the molded lip meets the bumper?
      does the aftermarket lip overlap your bumper?
      ^^MRT^^
      THIRD EYE FISH
        Are u talking about the aggresive or mild design?
        92 Accord Coupe (MR Thread Below)
        Member's Ride
          duno about cuttin your bumper you should be able to just put the lip over your bumper
            weird, i didnt no u have to cut along the oem trim in the rear, thats lame.
            edit- 4,020 post.
            herb time!!!!!!!!!!!!
              Do not cut your bumper... just cover over it. Then use some self taping screw to secure it.
              Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
                i cant afford a rear lip, so i did a diy on my cb for a rear lip. works just fine!
                  I had the the Xenon Mild rear lip and didn't have to cut anything.
                  double side tape follow up with self tapping screws in the middle and bolts/nuts on the end.
                    Just do the DIY CD5 rear lip mod if you're on a super tight budget
                    See p5ylance's write up in the DIY section.
                      you have to cut.
