Removing door panel
    Removing door panel
    I'm driving a standard coupe. Doesn't have powered windows, and requires a pin to be removed from the window crank. Has any body removed this? It's very hard to get at.
    Use a small FLAT HEAD, and push the pin out.
    MRT
      Are you sure it's a pin? I remember it being "C" shaped spring clip. If it is the spring clip, you can use an old rag to back it out.
        they make a tool for that clip
        2013 Ice Cream Cruise!
        VIDEO: 2012 Ice Cream Cruise
        VIDEO: 2012 Ice Cream Cruise part 2
        The single largest cruise in the Midwest!
        August 3 ~ Omaha, NE
        By 1320 Video
        Member's Ride Thread
          You'll need to push in on the door panel rather hard right by the window crank and then use a small flathead to pry out both sides of it. You may be able to get one side out and then use needle nose pliers to take it the rest of the way out but it's a tight fit. Also watch out when removing it because if you're not careful when it comes off it's going to spring off and fly through the air into the unknown lol. They're hard to find sometimes.
            Hey, I got it. Yeah it's a c shaped clamp thing, it wasn't too hard when I figured out it wasn't a pin, heh. Thanks guys!
