i really dont know the problem of my cb but when i stop or the temp of the engine is where is suposed to be the car goes straight down to 500 rpm ist looks like i will turn off but then goes up to 750 rpm or 800rpm...... is someone now wat can be plz let me know.....thanks
engine rpm question??????
cold start it'll be at 1500 or so, then it'll drop off to 600-700
if it isn't where you want it, adjust idle screw
you may want to adjust the base idle first...THEN adjust the idle
to adjust base idle
turn on engine...unplug iacv AFTER the car warms up...the rpm's will lower.
Set idle to 500 rpm, turn engine off, plug in
turn on engine...should idle around 600-700 or so, under 1000 though.
from there you can adjust the idle screw a bit more...you just wanna make sure the base idle is right...help to rule out other problems.
if you do this and still have issues...could be something else...so post up the results after you try that____
Originally posted by bcjammerx View Postcold start it'll be at 1500 or so, then it'll drop off to 600-700
to adjust base idle
cant you leave that pluged in and just jump the plug that you use for the check codes?
93 cb7 ex coupe
Granada Black Metallic
Originally posted by luisitopr12 View Posti really dont know the problem of my cb but when i stop or the temp of the engine is where is suposed to be the car goes straight down to 500 rpm ist looks like i will turn off but then goes up to 750 rpm or 800rpm...... is someone now wat can be plz let me know.....thanks
But, i'll try to give you my 2 cents. Its already been suggested that you adjust your idle. Also you've been told how to do it.
My question, is your idle bouncing around alot? Up and down, up and down? Somewhat quickly? If so, you might have a vacuum leak, Go threw and make sure all your vacuum lines are connected, make sure none of them are cracked and leaking. Make sure none of them are clogged up. Vacuum leaks will cause your idle to go crazy. I have a vac. leak right now, i've just been too lazy to fix it.
Hope i've helped.
Before you start randomly adjusting things you don't understand, read this:
http://www.cb7tuner.com/vbb/showthread.php?t=146239
And please try to post in the appropriate sections in the future. This is not an Appearance question.
