Having problems with my HID kit - Need some Suggestions..
    So i tried installing my HID kit for my Low Beams today.. i got them connected up but when i try to turn my lights on.. nothing, however my corners + high beams work fine..
    I removed my battery during the installation in order to have more room..
    What could be wrong?
    Have you tried to reconnect your original stock bulbs to make sure your wiring is good? And what type of ballast do you have, the slim design or the bigger one?
      SPECS:
      - Ballast Dimension: 2.4 x 2.8 x 0.5"(60 x 70 x 13mm)
      - Ballast weight: 8oz (230g)
      - Operating voltage: 9-16VDC
      - Nominal voltage: 13.2VDC
      - Nominal current: 3.2A
      - Max current: 15A (100ms)
      - Power output: 32-38W
      - Operating temperature: -22F to 185F (-30C to +85C)
      INCLUDED:
      - 2 HID bulbs (your choice of size and color)
      - 2 ultra slim digital ballasts with igniters
      - all the necessary plug n' play wiring
      - 15-yr warranty on ALL components of the kit
      Thats what I have
        if u have the plug and play odds are the power/ grounds on the main headlight connecter just switch the power/ground around and try.thats what mine did.
        my new turbo build
          what you should do is ground to the chassis and if you can, run a power from the battery with an inline fuse and a relay.
          Essentially, if thats the exact kit you have, you may just have to double check your conections.
            its the exact kit i have
              I had to turn the plug around on mine...
                x2... I had one light on and the other was off. Had to turn the one that wasn't on around near the ballast leading to the factory housing... Hope thats what works for you man.
                CB7Tuner Resident Gamer!
                PSN: JDMcb7TX
                  you need to invert the ground cable, should work
                  did work for me
                  CB8-Tuner
